********SOLD***********
Yes a 162" black LE. I changed from a 153 to a 162 and powder coated all the rest of the suspension parts while I was at it. Everything is black...Sled is like new with only 650 miles on it. Runs flawlessly. I run it at 11 pounds on 100 LL fuel.
Fastlane No-Snos
Fastlane vents in shock tower
Bdx vents in front bumper
Holz re-valve on all 4 shocks
SLP SLT Skiis
Ice scratchers
Knee pads
A/F Guage w/ dual mount cutler bar bracket
Mad Scientist guage cage
M1000 intake boots /reeds (for billet Cutler throttle bodies)
Mountain Addiction Gas rack
Cutler Stage 3 Turbo
*****MAY CONSIDER SELLING TURBO SEPERATELY IF THE PRICE WAS RIGHT******
M8 Turbo Kit "Stage 3"
This kit is the ultimate in performance. You can customize this kit to run on pump gas or you can turn up the boost and run race gas and smoke your buddies. The kit includes the following parts: 50mm Duel Injector Throttle Bodies, High Boost Actuator, Hallman Pro Boost Adjustor, Two High Impedance Fuel Injectors, Stainless Steel Turbo Flange, In Tank High Volume Fuel Pump, Stainless Steel Hardware, Graph Oil Seals To Prevent Boost Leaks, Stainless Steel Turbo Bracket, Equal Distribution CNC Machined O Ring Air Box, Stainless Steel Laser Cut Boost Bracket,light weight Mandrel bent one piece Charge Tube, Scratch Free Laser Cut Aluminum Brackets, Garrett 2860 or 2871 Ball Bearing Turbo, Boost Gauge & Fuel Pressure Gauge, Fully Vented Oil Tank, Attitude Fuel Controller, CPC 10,000 Hour Life High Volume Oil Pump, CPC Adjustable Blow off Valve, Exclusive CPC Cold Air Intake, CPC Adjustable Fuel Pressure Regulator, Quiet Muffler, CPC Clutch Kit which includes CPC Adjustable cam Arms, CPC drive spring, helix and CPC Torsional Spring Driven Clutch Conversion Kit. This kit retains the stock oil injection system. Maximum boost is 18 lbs depending on elevation and fuel octane.
M8 stage 3 Retail $5799.00
Sled located in WA state
$13,000.00
http://s786.photobucket.com/albums/...action=view¤t=ArcticCat-CutlerTurbo.mp4
Fastlane No-Snos
SLP SLT Skiis
Ice scratchers
Knee pads
$13,000.00
