This is a tip on power valve gaskets on these 800 cfi engines, there are at least three different power valve gaskets that I have that will fit this engine and all three are different. This is for guys that have cleaned their power valves and replaced their gaskets if you put the wrong ones in the valves will not work properly. (found this out personally) some of the gaskets have the center hole cut to large and the power valve won't seal, you need to pay close attention to the power valve housing. The little round hole is not all that has to seal the housing has a larger longer hole that covers clear across to the other side to the other small hole. that larger oblonged hole has to seal to the cylinder or the pressure will not open the power valves properly the pressure will leak out in to the exhaust. the gaskets with the larger center hole do not seal properly and cause rpm issues on top end ( found this out personally) polaris has a new gasket now for this problem the hole in the center is a lot smaller I will post the part number tomorrow but I was having issues and found this and my sled runs better than ever now. I wanted to pass on this simple thing ( that most like me never even thought twice about) that causes runability issues. hope this helps others out there.
