Upgrade to Premium
Ski-Doo: TURBO Turbo discussion for Ski-Doo aftermarket turbo sleds
Reply
  #1
Old 12-01-2017, 10:16 AM
kfa670 kfa670 is offline
Currently: Not set.
kfa670 has a reputation beyond reputekfa670 has a reputation beyond reputekfa670 has a reputation beyond reputekfa670 has a reputation beyond reputekfa670 has a reputation beyond reputekfa670 has a reputation beyond reputekfa670 has a reputation beyond reputekfa670 has a reputation beyond reputekfa670 has a reputation beyond reputekfa670 has a reputation beyond reputekfa670 has a reputation beyond repute
Garage
Default Cylinder Scoring
Just doing a some yearly check up with my bore scope. Here is what the backs of my cylinders are looking like on my turbo sled. The motor is a fresh rebuild as of last year by SHR. It was easily twice the turbo sled after BJ and friends sent it back. I did however have a problem with my fuel controller and experienced a few lean runs and pops. Does this look like serious damage or am I being too paranoid? I did finally figure out the fueling problem. A bad RAVE sensor was shorting out my electronics. Fixed that at the end of last year and everything is back to being peachy. Compression is still spot on.
Any advice is appreciated!
Click image for larger version
ID:	289056   Click image for larger version
Rate this post: Yes | No
  #2
Old 12-01-2017, 01:17 PM
Bendy Bendy is offline
Currently: Dooin the Snowdance
Bendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond repute
Default That serious!
That is not good at all. Sorry to be the bearer of bad news.
The Following User Says Thank You to Bendy For This Useful Post:
kfa670 (12-08-2017)
  #3
Old 12-01-2017, 01:48 PM
Currently: Not set.
Garage
Default
Damn
That's kind of what I figured
How easy is it to do the top end with the engine in the sled? I've done one on a ptek it wasn't too bad so I'm assuming about the same
  #4
Old 12-01-2017, 01:50 PM
Default
Same here. I assume it wouldn't be any harder than a P-tek. You will have additional electronic components. Its still a mono-block.
kfa670 (12-08-2017)
  #5
Old 12-01-2017, 06:59 PM
sledsrock sledsrock is offline
Currently: SUMMER SUCKS!
sledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond repute
Default
Lack of oil or water ingestion.
The Following User Says Thank You to sledsrock For This Useful Post:
kfa670 (12-08-2017)
  #6
Old 12-05-2017, 01:58 AM
xpturbo600 xpturbo600 is offline
Currently: Not set.
Basic Member
xpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond repute
Default
That looks like it is from water ingestion. Is it on the intake side? If it has compression and it runs, I would ride it. I had similar scuffs from sucking snow through the turbo and rode the sled to 2500 miles. It may last, or you may start losing compression. Rideability depends on compression. Nikasil can look rough and not be that bad to the touch.
The Following User Says Thank You to xpturbo600 For This Useful Post:
kfa670 (12-08-2017)
  #7
Old 12-05-2017, 11:52 AM
Currently: Not set.
Garage
Default
Yes this on the intake side. I'm going to take a peak at the backs of the Pistons when I get a chance and maybe see if I can sneak my finger in there without pulling the heads.
I took it for a ride Sunday. The thing just runs great. I had two little bogs/pops but I also have old fuel in there.
As far as water inhalation, it could have happened before I put my cold air on but I think it is highly more suspect that maybe it got too hot on a big pull I did riding double last spring. I got to the top and it acted like it wanted to die (sticking?) Took me a bit to get it started at the bottom again. Could that scuffing be from a lean condition?
BJ says send it over for a quick work over and some new porting... Hard to take it apart when it works so good
Don't want to get stranded this year though. New 175 for back up though
  #8
Old 12-06-2017, 10:36 PM
Currently: Not set.
Basic Member
Default
I am not there to see everything in person to say much more than I have said. To me, if the compression is good ride it. The piston will mirror the cylinder. If it was bad seize, it would likely test lower compression and/or have other signs of damage in the skirts or ringlands. There could be several reasons why a sled would lose power and be hard to start like you described. I have seen electrical issues display similar symptoms. Your description isn't enough to say a spring ride caused the scuffing.
Also, I would not port a turbo motor. I know a lot of engine builders who spent a lot of R and D time and money researching it. Their conclusion was the performance gains and losses do not justify the cost. Turbo engines behave differently and benefit from lower port timing and different port velocities than an NA motors. However, if you want to do it. Make sure to find someone who has real data to back up their claims. Otherwise, you may spend a lot of money for without realizing useable HP and instead get some peak number you see for 5% of your riding.
1 out of 1 members found this post helpful. Rate this post: Yes | No
kfa670 (12-08-2017)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — cylinder scoring Thread Starter — Snowbird11 Forum — Polaris: IQ Replies — 10 Last Post — 10-24-2012 01:37 PM
Thread — Slight cylinder/piston scoring - Hone or replate? Thread Starter — TheBreeze Forum — Arctic Cat: TURBO Replies — 19 Last Post — 02-12-2012 09:11 AM
Thread — Cylinder Scoring - Cause? Thread Starter — TheBreeze Forum — Arctic Cat: M Series Replies — 23 Last Post — 09-15-2011 10:03 AM
Thread — Piston scoring! How much is to much? Thread Starter — SnowBound Forum — Performance/Modified Replies — 7 Last Post — 05-06-2009 08:02 AM
Thread — Piston scoring 07 d7 Thread Starter — srosscojw Forum — Polaris Replies — 0 Last Post — 12-19-2008 11:53 AM
no new posts
