Upgrade to Premium
Ski-Doo: TURBO Turbo discussion for Ski-Doo aftermarket turbo sleds
Reply
  #1
Old 11-29-2017, 01:36 PM
Marcusx200 Marcusx200 is offline
Currently: Not set.
Basic Member
Marcusx200 is an unknown quantity at this point
Default Skidoo dobeck box turbo
Many post from me here now😆
T3 16 silber kit 5lbs spring
First test ride today and it runs like garbage. Does anyone have any "fall safe" setting? It ran best on everything on 1(low)
3000ft here . 98oct swedish fuel.
WOT it displays like 11afr at first
Rate this post: Yes | No
  #2
Currently: Not set.
Basic Member
Default
Also at first ecu detected knocking
  #3
Old 11-29-2017, 04:52 PM
Mwenzel Mwenzel is offline
Currently: Not set.
Basic Member
Mwenzel is an unknown quantity at this point
Default
silber dobox is good for nothing more than wall art. I have a redline from Bryce @ turbo performance. There is a thread below about the aurora which sounds really good, but I do not know much about other than what ive seen on here. @ roughly sea level and 3 and 5 lbs of boost with 50/50 93 and 110 I have no det issues.
  #4
Old 11-29-2017, 04:56 PM
Currently: Not set.
Basic Member
Default
https://cdn.shopify.com/s/files/1/07...79558548488280
here is the link to base #s for the silber dobeck
also from experience. be careful to over rev else you will destroy the reeds.
  #5
Old 11-30-2017, 03:57 AM
xpturbo600 xpturbo600 is offline
Currently: Not set.
Basic Member
xpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond repute
Default
It sounds like your misfiring and the ecu is picking it up as knock. You should try leaning it out since 11.0 is rich, even for a wide open pull. If that is off boost, drop the green only setting. Green blue is light boost and red blue is main jet boost at full throttle. Red only is main jet no boost. Also, both green settings somewhat function like transition fuel maps. Next, Yellow settings are global fuel add/subtract, so try not to mess with them unless you have too. If you watch the box as you ride, you can see it cycle through the settings. Thats will help you tune it. When you say crap...does the sled sputter and backfire?
  #6
Old 11-30-2017, 06:52 AM
Currently: Not set.
Basic Member
Default
Talked to our snowmobile guru here in Sweden and he told me 2 stroke turbo is russian roulette at elevation under 4000ft
True? I live about 500ft over but will be driving at 2-3000ft
  #7
Old 11-30-2017, 07:15 AM
Currently: Not set.
Basic Member
Default
Quote:
It kinda dies like blowing a plug.
I took a look ät the silber ecu manual and my harness hasnt the 5 and 6 ( coil 1 and 2) ?
One more thing , does it matter which Cable goes in to the injector? I mean which side? Just plugged mine in
  #8
Old 11-30-2017, 04:07 PM
Currently: Not set.
Basic Member
Default
not sure how much luck anyone else with the dobox has had @ low elev but the redline allows for much more manipulation. this is what my map looked like from the start
Click image for larger version
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 3.5 dobeck box for 4 injector turbo pro. Thread Starter — Hairy Mark Forum — Turbos/Superchargers (Swapmeet) Replies — 0 Last Post — 02-14-2014 11:28 AM
Thread — What can a Boost-It do that a Dobeck box can't? Thread Starter — BigAir Forum — Arctic Cat: TURBO Replies — 4 Last Post — 08-07-2013 11:11 AM
Thread — How many with Dobeck 3.5 box troubles??? Thread Starter — ling Forum — Polaris: TURBO Replies — 10 Last Post — 12-26-2011 01:57 PM
no new posts
