Upgrade to Premium
Ski-Doo: TURBO Turbo discussion for Ski-Doo aftermarket turbo sleds
Reply
  #1
Old 03-27-2017, 12:36 AM
TreeThrasher TreeThrasher is offline
Currently: Not set.
Basic Member
TreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond repute
Default Redline fuel control
Anyone using the redline fuel controller on a turbo doo? Any run ability issues over varying conditions?
Thanks!
Rate this post: Yes | No
  #2
Old 03-27-2017, 09:33 PM
Backcountrypro's Avatar
Backcountrypro Backcountrypro is offline
Currently: Preparing to get a education in boost!
Backcountrypro has a reputation beyond reputeBackcountrypro has a reputation beyond reputeBackcountrypro has a reputation beyond reputeBackcountrypro has a reputation beyond reputeBackcountrypro has a reputation beyond reputeBackcountrypro has a reputation beyond reputeBackcountrypro has a reputation beyond reputeBackcountrypro has a reputation beyond reputeBackcountrypro has a reputation beyond reputeBackcountrypro has a reputation beyond reputeBackcountrypro has a reputation beyond repute
Default
I installed a Redline fuel controller on my 2012 Turbo Etec this year. I bought my fuel controller from Bryce at Turbo Performance. He did a great job of getting me set up with the tuning software and the how to's of the programming. I had to tweak the map from the original but once that was done it ran great. The fueling is so crisp and consistent no matter what temp, elevation or boost level you run.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to Backcountrypro For This Useful Post:
brycter (03-28-2017)
  #3
Old 12-06-2018, 11:13 PM
nbarels nbarels is offline
Currently: Not set.
Basic Member
nbarels is an unknown quantity at this point
Default
Quote:
What did you have to change?
  #4
Old 12-07-2018, 12:38 AM
fredw fredw is offline
Currently: 850 blown up before Breakin over
Basic Member
fredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond repute
Default
Had a little hick-up with mine last year, would run perfect all day and then when comming off the mountain it would short out.. Needed a reset and perfect again.. I think Brice had some good info on this.. Took mine off and would like to reinstall again if fixed up, it ran that perfect on the Aerocharger
  #5
Old 12-07-2018, 11:10 PM
Default
Quote:
I am running the larger 2871 turbo vs the 2860 that most kits have. I had to add more fuel than the original programing called for. Its no big deal to do with the Redline box. Highlight some cells.....multiply by what ever increase you want to go as a percentage and you are good to go.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Redline fuel controllers? Thread Starter — catmanm7 Forum — Arctic Cat: TURBO Replies — 7 Last Post — 01-29-2018 09:58 PM
Thread — Redline fuel controller Thread Starter — brycter Forum — Ski-Doo: TURBO Replies — 5 Last Post — 10-08-2016 11:46 PM
Thread — redline fuel controller Thread Starter — brycter Forum — Polaris: TURBO Replies — 0 Last Post — 09-13-2016 08:22 PM
Thread — Anybody using redline performance fuel controller? Thread Starter — chad006 Forum — Ski-Doo: TURBO Replies — 1 Last Post — 12-20-2015 10:13 PM
no new posts
