If a 2012-2015 was setup properly they were just fine.
The TEAM stuff is a large step in the right direction.
The amount of holes is indicative of cheap *** metal used in the manufacturing process. If a better grade of recycled aluminum is used, it costs more and is more consistent.
Team clutches are built for the absolute least cost possible in every aspect. If this means they can save 25 cents using recycled beer cans full of dirt, beer and insects, then that is what they will use.
Don't try to defend a junk metal and manufacturing process done in China selling each clutch for $20 each to dumb North americans.
Actually they do their castings in the states. If they were cheap junk, they wouldn't be providing nearly every oem in the industry with product. Lol
Ya, ok. They supply nearly all the oem's so that means the clutches aren't cheap junk.
There's prolly more 6.0 Ford powerstrokes than Team clutches out there also. By your reasoning, there's millions of 6.0 powerstrokes so the motors can't be junk.
What oem sleds are belt burners? Why so much clutch heat? Who makes the clutches? Yep, Team. That's who. Why can 250 hp turbo 4 stroke yamaha 700lb tanks go for a year on the same $40 belt? Because they don't run team clutches, that's why.
The evidence is staring you in the face. Look at the clutch that has up to half the circumference drilled to come close to balance. This is laughable. It's not normal but people accept it simply because half the sleds have Team clutches.
Why did this only happen when Team started making clutches? It never happened on earlier sleds.
If you can't see it for what it is, I can't help you.
Just keep buying belts and replacing clutches. I'm sure you will figure it out someday. LOL.
