To go along with the other thread on clutch balances on the PC I found out some interesting points from a dealer in Utah. I stopped at the dealership to get a puller for my PC that I will be picking up next week. I bought a used one. ( After all the crap I've been reading; What was I thinking; I should have bought a holdover 011). Anyway the parts manager told me that the PC clutches are out of balance on purpose to offset the out of balance crankshaft. If you pull the drive clutch and don't install it on the shaft in the exact same location as Cat installed it, you WILL GRENADE the engine. If you have the clutch rebalanced you WILL GRENADE the engine. Apparently there is an alignment mark on the cover plate and one on the back of the rear sheave and on the case. Now I'm not sure on the marks because he rattled them fast and also because my mind was already in overdrive telling me; "What kind of stupid crap is this". I might be incorrect on the placement of the marks. Be sure to contact a dealer to find out for sure on this. Surely there should be a bulletin from Cat stating what I just said. I wish I had my PC here to look at but maybe some of you people could check and see. The mark on the cover is supposed to be small round mark of some kind. Let me know what you find out.
