A
2014 M8000 w/ TKI belt drive already installed.
Before I start swapping out the jackshaft have a few questions for anyone that has done this.
I ordered the jackshaft from Evo powersports, which is really the OSP jackshaft (just didn't come with bearings like the one from OSP does). Note came with it that said to go to one stop performance web site for installation video. OSP video only shows install on the 1100 so it's not quite the same i don't think?
1.Do i need to remove the TCL to get the jackshaft and PTO bearing out? Going to replace the PTO side bearing as well. It appears the snap ring holding the bearing in can be removed without removing the TCL. This isn't like an upgrade to a 2015 shaft, so i'm thinking i don't need to.
2. Can i hammer out the PTO side bearing from the mag side using the jackshaft without damaging the TCL? this is how they show it in the video.
https://www.youtube.com/watch?v=a-tXv8lWSRI&feature=youtu.be
3. Note that came with the shaft says "The chaincase collar may need to be turned down to work with your belt drive. Check pulley alignment and remove material from the larger OD side of the bushing." Anyone that has installed this shaft with the TKI belt drive, did you find the need to do this so the top gear was aligned? how do you check alignment?
4.How does the chaincase collar get installed? large OD out/small OD side in i assume?
Thanks in advance.
Thanks in advance.
