Code de7
DirtBoss
Mar 8, 2006
Lake Tapps, WA
13 800 Pro with SLP pipe, can, PC V, and SLP's clutching started throwing code de7 periodically while headed back to the snowpark yesterday. Ran flawless and without this code on numerous long wide open pulls. RPM's 8,000 to 8,200.
Any ideas Polaris guru's?
dcturbo
979
228
WYO
Witch gas plug are you using? Ethanol or non ethanol?
If you have the non ethanol plug in go with the ethanol plug. It will retard the timing just a touch and could fix your det problem.
DirtBoss
Mar 8, 2006
Lake Tapps, WA
I'm running it on the non ethanol setting (adjustable via the gauge on the 13's) and running non ethanol 91. Good idea to switch it and see if that fixes my problem
philsummers21
2,437
486
41
Big Horns, Wyoming
I can get mine to do this when im screwing around on the trail listening to my damn blow off valve. Just something i can't do. Probably the same with your pipe and PCV probably tuned right untill you start blipping the throttle all retarded like on the trail. At least thats my take on it.
DirtBoss
Mar 8, 2006
Lake Tapps, WA
I'm going to see if adding some midrange fuel will help with this as it is happening 3,500 ft and below.
Thanks for the help guys!
die hard poo
1,177
796
Kenai, AK
I bet its because you are hitting the rev limiter on the hard pack trail. Either add more weight to your mtx weights or live with the potential for the det and bog on the trail... If you switch it to ethanol, it will add 5% fuel across your map making it richer(doesn't adjust timing), which potentially will help this situation, but it is because you are making less power. I would rather add a gram or two to your slp weights...
DirtBoss
Mar 8, 2006
Lake Tapps, WA
Update
Talked to SLP this morning and they are building a new map for this setup as other peeps are having the same issue.
According to them it is triggering the det sensor on decel below 3,500'.
Feb 8, 2011
150
37
Minneapolis Area
New to the Rush. Bought a 2010 600 for my son last year. We own 4 RMk 900's but this is the first rush. He came home today and said he got the de7 (det) code. You guys were talking about an eyhanol plug...what is that. All the gas around here has ethanol.
Apr 3, 2014
De7 code
I was just cruising down the trail and got the de7 code. The sled then went into limp mode. Pulled over to check things out. Was playing around with clutch to make sure no weights were hung up. After a few minutes the clutch locked up solid. As anybody had this happen to them?
Octanee
1,188
217
Cranbrook Bc
Did you figure out what happened? this happened to me yesterday
Seems to be a unfortunate common issue with the pros, I my self am battling it - on off the throttle. Usually on or around the trail. However turbo'd., I've read everything from tps to fuel filter, to it picking up a metallic noise somewhere like the front exhaust mount. :juggle:
gtwitch
394
201
Laramie, Wyoming
After reading all of the responses here, No one has mentioned checking or replaceing the fuel filter!!!! I burned one up thinking it was octane problems but was lean because of a restricted fuel filter. Cost me two pistons and gasket set last spring about this time. Old dogs can still learn new things--- fuel filter!!!
gtwitch in wyoming
