CFI FUEL SYSTEM, INJECTORS, STORAGE,PLUMBING AND OUR CRAPY FUEL THESE DAYS
mountainhorse
18,606
11,814
West Coast
www.laketahoeconcours.com
Today's ethanol added gas and even gas last season that did not have ethanol is not the best quality and does not store very well...So bad that fire dept are switching to fuels like VP's SEF 94 for stability reasons and ability to store well.
Click here for VP's SEF-94.
With our crappy gas these days... and VERY short storage life before deposits form... IMO...At the end of the season... add marine grade stabil to the gas in the last month of riding (you really never know when the last ride is for the year)...
Fog the motor after you know you've done your last ride.
Then, drain the tank completely... run the pump in prime mode with the return line disconnected and into a bottle to get the old fuel out of the lines... disconnect the line at the fuel filter and blow out the fuel with DRY compressed air, or preferably nitrogen at 45 psi.
Then, hook everything back up... install a new filter and you are ready for the next season.
OR... Drain your system, install a new filter and run the SEF94 thru the system at the end of the year...
Personally, I'm going to pony up for some SEF 94 for the end of next season (building this season with new motor and injectors etc).
If you have an EFi sled... IMO.. you should send in your injectors to get cleaned and checked for flow/symmetry each summer so that you KNOW, absolutely, that the injectors are not your weak link.
The ethanol can carry water with it which can corrode the pintle/seat in the injector.
Running fuel system cleaners at the beginning of the season to try to deal with this can actually make your problems worse... they can loosen gums and varnish in the tank/plumbing and clog filters, pump rotors and injectors...plus they can soften some of the plastics used in the sleds fuel systems.
Not that cleaners don't have a purpose.. IMO... they are a good Maintenance "tool" that can be run through the season to keep things clean... but if your EFi system is dirty already...don't do it IMO.
Also, with many people fueling from gas-cans... a lot of dirt etc can get into the system... IMO...ALWAYS use a funnel filter and make sure that your cans are always sealed after each use and kept clean inside.... Dont use old fuel no matter how tempted you are.
I use Witch Hunter Performance in Wa. for my cleaning and flow testing of injectors.
I like to be able to depend on my equipment each year... and don't want to leave this stuff to chance.
Also, for you new sled owners out there with extended warranties..the warranty does NOT cover fuel related issues like gummed up injectors etc.
If your motor burns down from clogged injectors... YOU are on the hook for the repairs.
I'm sure some will chime in and say that "I've not had a problem...I never needed to do this..." which is good for them.
All I can say is that the gas HAS changed in the past year or so, it will probably get worse and my riding time is too important to worry about this stuff... Preventive maint can go a long way towards a happy season. :face-icon-small-hap:face-icon-small-hap
My 2 cents.
C
CompFusion
133
62
Newfoundland, Canada
I've always preached the use of fuel stabilizer during the last half of the season. If you run it regularly then it's already in good shape for the summer. Thank god we don't have the ethanol issues here yet...but I expect it's coming sooner or later.
mountainhorse
18,606
11,814
West Coast
Thanks Matt!
Race Fuel will go Bad.. Just Normally takes longer..
Some race gas will go bad in a couple of days if it gets too hot too.
SEF 94 is much more stable than normal race gas... It really isn't a performance gas... mostly for storage... Better than pump gas by a long shot...but cost is about $9/gallon in 5 gallon pails.
