I asked them on Instagram and they told Me it will fit the 16-17. Does anyone have a part number for the 18 t-stat.
From what I'm gathering, you need a new head, cover, o-rings, and thermostat housing. Thermo housing isn't even coming up yet on the parts fiche. Retail for everything needed is over $800. Probably in the $600-700 range if you buy everything from Michelle @ Cannon Powersports. Parts won't even be available until Oct 9th or later. Funny thing is the 16/17 head is under $200 when the new 18 head is $738. Seems like Polaris is trying to steer people away from upgrading.
Ok,so my dealer just called me back after I ordered the 18 t-stat., and it won't fit in the 16-17 head. You need the 18 head for it to fit. Also the pipe bung has changed for 18, so pipes off the 16-17 Will not work.
Could be better if you had an aftermarket head or a turbo cooler engine would be less likely to detonateIs fuel mapping the same in 18s as it is in 16/17? I was told it is pretty close to the same 100-127f as long as pipe is up to temp (can somebody please confirm?). If thermostat isn't direct drop in I am trying to see if it's worth it to drop temp down on a 16 sled. (1 hp?)
One of the first things I did to my Pro and my Axys was take out the thermostat and throw it in a box, never to be seen or heard from again. Temps are down in the 80's and 90's ALL day. Sled runs great (might have something to do with the shaved head, TKI gearing, SLP pipe, and Diamond S can :face-icon-small-win).
As you can tell, I wouldn't bother upgrading this part since I don't even keep it in my sleds. Save the money and just take the thing out and never look back. Just my $.02
This is interesting. Reading the comments, it sounds like Polaris might have scrapped the external T-stat? Not sure I like that.
One thing I see is the diameter has decreased significantly in the plunger. There are Pro's and Con's with this. Better for cold shock but worse for volume of coolant which doesn't help once you begin to heat up on those iced out goat trails.
I think Rich might be onto something with the head cover from a Pro but I am going to take a stab and say the coolant passages HAVE to be different with the 2018 head.
Not really sure we need to upgrade a 2016-2017 800HO.
