Temporarily, I am using an early 90's Arctic Cat Coolant Reservoir till I can find the time to make an aluminum oil reservoir. The Coolant reservoir doesn't hold much oil but enough to get a good test ride in. The 08 RR 600 had a oil reservoir that will work on these but I havn't looked into what it would take to make it bolt up to the steering column. JS Powersports carries the RR tank for $131. http://www.jspowersports.com/polaris_iq_oil_injection.htm
Can't seem to find my pics of the final pipe setup but I did the stock pipe with one cut to the pipe and tilted the y-pipe up a bit. I then used a MBRP race silencer from a 04 600 switchback with about 5 cuts to the outlet to fit the stock bellypan hole.
