any replacement ideas for the vacant holes if I do pull the lights?
Go buy some 1/4 inch harware cloth and pet screen.
Cut and form the hardware cloth to fit nicely in the openings from the backside, then cover with the pet screen and attatch using the old headlight mounting holes and replace the windshield push pins with fasteners so you can attatch the hardware cloth and pet screen.
Be sure to extend the cloth far enough so you can attatch it.
I have been waiting to post pics of mine until I have finished some other small details, but I should be done with it this weekend and will get some pics of the vents and custom airbox.
I was running a small automotive light under the hood on the steering support, but have since moved it to the top of the hood just below the divider in the center of the headlights.
I used a rubber pad to keep from scratching the paint on the hood and attatched it with a couple zip ties.
If you cant find pet screen, the uv screen door material looks to be close to the same thing.
I used regular screen door material and it is not quite as strong as the uv screen, but the regular stuff is more porous.
