H
190 hp mod sled
the motor is based of a 780 it has a total preventative rebuild 300 miles ago. pistons rings bearings and gaskets. 1200.00 alone the motor is estimated at about 190 horse. I run 97 octane in it because of the high compression ratio. It runs very strong. I love it but it must go. I am willing to sell the motor alone or the whole cat.
925 triple with triple crankshop pipes, and stingers
kehin 39 mm bored to 40.5 set up with jets and needles
jackshaft has been lowered below the tunnel
dropped chaincase down two inches and back 3 inches
chaincase is stock with 20/40 gears
15 wide hyvo chain
02 polaris 800 primary with 60 gr weights and a dark blue spring
arctic cat roller secondary
eight tooth anti-ratchet drivers
polaris 11 gal gas tank
boss light weight seat
a polaris 151 rear suspension with extensions for a 162
ryde fx shocks in the rear
camoplast 162 x 16 x 2.5 track that is ported with three holes
eight inch black wheels in the rear
custom front cooler, with stock polaris running board and rear coolers
HRP radius rod front end with all new joints.
light weight super lite trailing arms
red simmons flexi skis
light weight clear hood
fabcraft high rise bars
Digatron dt-54 4 window egt (cost 550 just 1 year ago)
3 probes , water temp, and rpm
hand warmers
set up with two mukuni fuel pumps just incase
ryde fx front shocks
3800.00 MUST SELL
15 wide hyvo chain
hand warmers
3800.00 MUST SELL
