BDX Pro Lite Update
backcountryislife
7,413
Dumont/Breckenridge, CO
So, just eliminating the 900 kit, or eliminating the pipe & can as well (and controller), or also getting rid of oil injection? I was just asking Jeff about ways to order this as a "kit" but my saying "stock motor" brought up more questions that I was expecting.
hd4rob
1,066
373
83
Lake Park, MN
I like the kit idea. I pretty much have everything here or on order to make my own black LE 162 "pro lite". But with an slp pipe kit and skis. Plan on doing a thread while assembling.
hd4rob
1,066
373
83
Lake Park, MN
Good call, seems like the bump stuff is the only complaint folks have on that sled.
Sent from my A200 using Tapatalk 2
That was my #1 fear/dislike(bmp). That and I don't know how the warranty situation will work when people can screw with the fueling through the power commander. They could say any engine failure was the riders fault for messing with the tuning.
K
knifedge
1,334
542
Colorado
--Just a question?
--How bad could BMP screw up a stock cylinder big bore?
-bore it out
-plate it
-port it
-install cylinders, pistons, head
-add pipe and silencer
-tune controller to spec
--Should run fine
A
ACMtnCat
1,359
Utah
If it was that easy, everyone would have a 200hp 900 kit.
I'd like to see it run at altitude in real conditions before buying into claims.
I would think a good 925 would be closer to 180 hp.
mmsports
3,140
1,623
Preston, Idaho
hubsperformance.com
901 kit
Ray has been running one for three years now and runs great. Better than any 925 I have seen.
You that are doubtful That is my job this year is to get you on it so lets hook up so you can see it run.
Hope to sell out this weekend in Edmonton.
--Just a question?
-bore it out
-plate it
-port it
--Should run fine
backcountryislife
7,413
Well then... in the name of science, you need to get to CO this year!!:face-icon-small-hap
J
JasonAK
759
134
So.... How does the warrenty work on the BDX sled?
Through Cat or BDX or MMsports? Is it just a parts warrenty?
Can you get 4 more years of Cat Care added to it?
Jason
J
Jordo
Nov 3, 2009
205
35
Stillwater,MN
My sled was the First BB 900 kit BMP did on the 800H.O motors and Rays was the second. Have have had no complaints/problems with my big bore, only thing I have done to the engines in 2 years and 5 trips out west which = about 2200 miles on the odometer in replace the pistons after my first year because BMP switched from Wiseco's to Wossner piston. Only BC BMP had those Wossner make those pistons just for there 900BB specs!
K
knifedge
1,334
542
Colorado
Is anyone interested in a Pro lite Turbo????
They would be 19999.00 installed dialed ready to ride.
If you are contact me I will build you one.
---The Pro-Lite seems to have the best factory options available I've ever seen
mmsports
3,140
1,623
Preston, Idaho
hubsperformance.com
Can you see the bumper?
