My oil pump was waaaaay out of adjustment, so far that I had almost ran out of threads on the cable and still only had it to were it should be (at the line). I wanted to go past the line a little bit but didn't want to have the lock nut hanging on by a thread or two. So after having the lock nut as far out as I dare go I reached in with a pry bar and tweaked the bracket that holds the cable to get a little more. After checking everything I noticed a small oil drip coming from where the bracket screws to the oil pump. I pushed it back and there doesn't seem to be any more drip.
Does anyone know if this is on the high pressure side or low pressure? There's only 2 screws that hold the bracket on unlike the older pumps that had 4. I tried getting in there and tighting those 2 screws for better piece of mind but there's no getting at them.
Can the pump be removed by just the to bolts or is there a seal that has to be pried out and replaced if I touch the oil pump?
If it's bone dry over night is there any reason to worry? Or will the pressure change when it's at high rpms?
