2003 highmark 700 starting problems after riding then resting.
B
Jan 25, 2013
3
My 2003 700 starts first pull before each ride but if I let it rest for more than a couple min after riding it will not start for atleast 20 pulls full throttle or not. Thought of what might cause this?
O
Jan 30, 2011
92
39
18
Black Hills
Be sure that your carb heater valve is turned off, that is the little red lever on the valve that controls the flow of antifreeze to the carbs to keep them from freezing in below zero weather or when the humidity is high (frosty), if the antifreeze is allowed to flow to the carbs in warm conditions I have found that when you shut the motor off the carbs will overheat and vaporize the fuel or cause it to expand and flow into the motor causing the motor to flood.
