M
09 146...blew first belt at 120 miles...anybody else having problems with theirs?
I can't believe he even got to 8700 RPM's...my rev limiter kicks in at 8500-8550.
2 in ~ 100 miles.
Two issues:
1. Apparently some of the new bushings (spring cap & other) in primary are out of tolerance. This is what they are replacing on mine - albeit the part numbers are the same - my dealer referred to them as "updated" bushings.
(more of just a loss of direction from BRP on what to do I believe).
2. Alignment. On a clutch that theoretically cannot be aligned I believe that there are some that are misaligned and causing a problem. I am taking it upon myself to align it - probably have to pull the lhs rear mount and machine the hole to allow movement.
my 2 cents worth anyhow........
I'll see tomorow after they replace the bushings whether I'll be getting 2 new belts on warranty.........
I drilled mine on the sled with secondary clutch in place. It was scary but best update done on my sled. 08 154, 6 belts before 1000 kms and now the next 1500 on the same belt. It still looks great.
ps you need a very long 1/2" drill bit. I used an old wood auger, it cut fast.
took till almost january for this thread--thats pretty good --none here on 5 new 09's
