Check out this thread about chain pitch. A few post down is a chart that you can download. This does all the math for you. You just need to measure the distance between the centers or your Jack shaft (where the small gear is mounted) and the drive shaft (big gear is mounted). Once you have that you can put in your gear tooth count and then it will tell you chain pitch. Good Luck
