I posted this in Perm. - mod but got zip.
I kind of need an answer fast so i am trying here also.
I am installing a set of Holtz spindles on my wifes 07 dragon.
What is the best way to adjust camber??
If I understand correctly you run a bar thru on side to the other and the end of the bar should be 3" below The top of the hole on the other spindle.
Is that correct??
What size bar should I use?
Will all thread work or should I use something else?
Is that correct??
