Hi guys i cant figure out how to get the water pump shaft out on my 09 800r xp. do i have to pull the motor? any info would help thanks.
Note: this_feature_currently_may_not_be_available_in_some_browsers
you dont have to take the lower plate off you have 2 remove the water pump impeller, theres 2 bolts behind it , remove oil pump, tap shaft out from oil pump side,if it doesnt come out, youll have to split the case! why r u taking it out ?
