P
The splines on the new jackshaft seems to be too long on the chaincase side.
I have C3 belt drive and here is some pictures.
The last pic is showing when the gear is lined up.
Somebody who knows what is going on here?
if they sent you the wrong shaft they need to send you the right one.
if they want the old one back its on their dime
Is titanium the way to go ? I though high carbon steel was tougher? Heavier but seems this shaft is a weak spot. Any input?
Machine a spacer that fits between the washer and the top sprocket and you should be able to use that shaft, correct? Since you are in Europe that would save you a lot of down time and money. IMO
I also got one of those 3 ti shafts they had. Worked fine with my tki belt drive on a 15 HCR. Only thing I needed to do was make a deeper cupped washer for the end cause the splines were longer. From what I was told they made the splines longer so you had full engagement of the pulley on the splines.
i am the third one that have that ti shaft . i machine/cut to install in chain case . fit nicely
Yes, it is 900 grams lighter then stock.
How are the ti shafts holding up? And how do you get the stock shaft out of the chaincase bearing? I'm beating the crap out of it & it isn't budging.
