3- seaters, 130hp, with reverse. Capable of pulling all water toys.
Have been maintained regularly with synthetic oil, and are already winterized.
Have 6 Machines available and package deals can be arranged.
Asking $6000 per machine
Have 2 Sea-doos in Calgary, AB:
Contact Mike @ 403-710-4058
4 Sea-doos in Sicamous, BC
Contact Paul @ 250-878-2701
-ENGINE Rotax® 4-TEC®, closed-loop cooling system
-Electronic Dash
-STARTER Electric
-TRANSMISSION Direct drive, forward / neutral / reverse
------------ other info ---------------
PUMP Composite / aluminum, axial flow, single stage, large hub with 10-vane stator
IMPELLER Stainless steel
PROPULSION SYSTEM Sea-Doo® Direct Drive
DISPLACEMENT 1,494 cc
BORE X STROKE 100 x 63.4 mm
COMPRESSION RATIO 10.6:1
IGNITION Digital inductive
INTAKE Naturally aspirated with 52 mm throttle body
BATTERY 12V
MEASUREMENTS
LENGTH 127 in. (322.5 cm)
HEIGHT 45.9 in. (117 cm)
WIDTH 49 in. (124.5 cm)
WEIGHTS
DRY WEIGHT 732 lbs. (333 kg)
OPERATIONAL
SEATING 1, 2 or 3 riders
FUEL CAPACITY 15.9 gal. (60 l)
Type: Regular unleaded
HULL MATERIAL Fiberglass
HULL TYPE Modified Vee
STORAGE 13 gal. (49.4 l)
-Electronic Dash
-STARTER Electric
BATTERY 12V
MEASUREMENTS
WEIGHTS
OPERATIONAL
