cheap power?
B
Dec 14, 2010
179
13
18
29
ya guys any suggestions for a 97 mxz 670? im thinking about milling the head or boring the pistion out a little bit.... mabey some new winesco pistions too but please i need suggestions
and i already have AAEN pipes
A
Sep 23, 2009
42
3
8
New rotary valve. I forget which one, but if you search some you'll find it. It came stock on certain ski doo models. Clutch work is always a good way to feel more power. Properly adjusting belt deflection makes a huge difference.
T
Apr 25, 2009
7
38
Willow River B.C.
Bore out the case ports like the X engines eyebrows, port match your cylinders and cases as well as your rotary plate and intake, Cut rotary valve to '501' specs. Short carb boots (93 mach 1 I believe) and a pair of 44's.
Ditch the aaens and track down an HO single pipe to get more bottom end.
