2008 Sno Pro 600 race with M8 motor, m8 float skid (long track) mountain. Colorado
B
Dec 14, 2010
53
1
8
Colorado
I have a very custom sled for sale. With that being said, this is not something you compare to the average mountain sled. The market for this exact sled is small, but I know it will go to the right person that is going to absolutely love it.
This has been such an amazing sled and I am sad to have to let it go. This sled is very fast and runs exceptionally well. You have to ride it to understand.
It started life as a 2008 sno pro 600.
It has an arctic cat m8 800 motor.
-Brand new top end with OEM pistons, rings, and bearings less than 20 miles ago. The entire bottom end was also checked and all new oem seals were installed. Everything was within specifications.
-Speedwerx port and polish on both cylinders.
-Speedwerx custom twin exhaust setup build specifically for this sled.
-Speedwerx and the arctic cat race team teamed up to tune the ECU to the pipes. The ECU still adjusts for altitude as well.
- M1000 throttle bodies (50 mm vs the 46 mm on the m8)
-Brand new injectors
-New OEM primary clutch installed last year.
-It does not have the factory oil injection due to reliability issues. You have to mix the fuel.
Belt-drive conversion from Swenson machine (this replaces the chain-case) More reliable, less drag, easy to change.
Custom tunnel. 2010 grab handle and snow flap.
Arctic cat M8 float skid with 155" 2.5" camoplast challenger extreme track.
Avid-products anti-ratchet track drivers.
Skinz hood and side panel vent kit.
2010 sno pro nose cone and vent kit
SLP powder pro skis
2010 Sno pro 500 11 gallon gas tank with internal fuel pump.
Skinz tunnel bag
Gas can rack
Sno pro front bumper.
Koso dual EGT, coolant, and rpm gauge (Brand new)
LED headlight.
I have 3 brand new extra oem belts.
and much much more...
The bad: A few scratches.
It is set up great, clutching is perfect, and it will out run pretty much anything on the mountain unless it has a turbo. If you have any questions or want to give me an offer don't hesitate to call or text. 719-2four4-6seven7seven. I am asking $6000 but send me your offers, I understand the market for this type of sled is very small. PM's are also welcome.
Sorry for the images being upside down...
Sled is located within 50 miles of Denver, CO. (Colorado Springs).
Thanks,
Landon
20151213_160127.jpg 20151213_160134.jpg 20151213_160140.jpg 20151213_160158.jpg 20151213_160056.jpg 20151213_160103.jpg 20151213_160110.jpg 20151213_160230.jpg 1924532_10203132217447182_1349765320_n.jpg
B
Dec 14, 2010
53
1
8
Colorado
6 years ago everyone wanted the sno pro 500 or 600 with an 800 motor in it and a long track... is their no love for this sled anymore? Send me your offers! 719-two44-677seven
