800 HO Y Pipe on Non HO Motor
02SummitX800
384
Will putting the HO y-pipe from a 2003 or newer 800 on my 2002 make any kind of difference at all?
J
JustinB
1,691
645
2003 doo came out with the HO and then stuck it into the rev half way thought the year. Not sure if it will work try it see if it lines up. No advantage the HO got its extra power from the porting in the motor.
Summit8
936
Fairview, MT
Yes, use the 03 Y-pipe, it has the doughnut gasket on the outlet and seals much better, and is replacable if it wears, I've got a couple extra, haven't had to replace first one since putting the 03 manifold on.
