Straightening/Stiffening running boards
1Fast68
124
Renton, WA
My 06 Rev's running boards are bit bowed, pretty standard design flaw IMO. I'd like to straighten them back out and add some Better Boards, WRP boards, factory stiffeners, whatever works best. I'm 260 pounds worth of hott sex, so I need these things to be solid.
Anyone have recommendations? How to straighten them, which to boards use, where to buy, the usual questions.
Bestow your knowledge / opinions upon me.
Gracias Amigos
J
Jun 13, 2009
1,032
218
Hailey, Idaho
I just installed the WRP boards and love them the boards are way stiffer. FYI you can also insert a 7/16 aluminum rod inside the board edges once they are straight to help keep them that way.
I got mine from Go big parts and they had them out super fast and every time I order from them I get good service.
M
mastertech
5,288
215
Cambridge/McCall Id.
www.snowestonline.com
I would advice against using a dead blow hammer.. Thats alot more stress on your rivits and everything else thats not needed.. All you need to do is put a automotive jack under the bent down part and raise the sled from it. Give the sled a ittle jar by putting weight on the seat and it will straighten it out perfectly! Than add your better boards...
sledsrock
510
Grand Junction, Co.
I would advice against using a dead blow hammer.. Thats alot more stress on your rivits and everything else thats not needed.. All you need to do is put a automotive jack under the bent down part and raise the sled from it. Give the sled a ittle jar by putting weight on the seat and it will straighten it out perfectly! Than add your better boards........or Monster boards
Not sure how big of a deadblow you own Master........maybe that's what's in your bottom drawer?.........lol. Actually they are quite soft and will return back to original position pretty easy......your idea sounds pretty solid as well.
R
Dec 12, 2007
354
105
Orting, WA
boards
You can use what ever means necessary to bend the factory boards back to spec. Then install "better boards". No more bending and no more snow build up. Good luck--Jay
R
Dec 12, 2007
354
105
Orting, WA
^ you can use what ever means... But those means arent always the best or the proper way to do it..
Im sure a torch and sledgehammer would not give the best results. Just use common since and the best means necessary and straighten the running boards. Then install your favorite snow eliminator/board stiffener. Gees :face-icon-small-hap
NorthMNSledder
Trail Coordinator
5,610
Ham Lake / Lake of the Woods, MN
:focus:
I picked up a set of the Artic Cat Rail edges from the new M Series for my REV and then I'm having Better boards build me a custom set of snow eliminaters to go with them. I'll get pics up when I have them installed. But if you order a set from Freeagent they are pretty resonable and they are super solid. Plus you can get them in a black finish now!!
J
Feb 19, 2008
1,544
791
Ogden
Guess I have been looking at REV boards long enought I didn't even notice they were bent. :face-icon-small-win
I use the jack and short piece of 2x4 myself. Works great! Those really aren't even bent enough to worry about to me. That just means you are having fun.
