I will post pics as soon as i get my camera back.
I went with the TC-1
I bought 2 RSI TC-4 extended throttle cables for our 2003 600HO and 800HO (both zx sleds).
Seem to be pretty well made, however the cable from the splitter to the carb is quite a bit shorter than the original
(meaning i have to re-route the cable to a different place)
and the oil pump cable does not seperate at the in-line adjuster as called for in the service manual for properly adjusting the oil pump.
The manual calls for pulling the cable housing apart and measuring the exposed cable to set proper adjustment, can't be done with the new cable. Sooo... I will have to see where the lever is adjusted on the sled I haven't taken apart yet and try to match it.
We'll see how this goes...
Waiting for the proper cables to arrive :face-icon-small-dis.
Will post pics after I get the new cables from RSI.
Probably not until wednesday.
Looks like the TC-1 cables will be the right ones for the ZX (not the TC-4).
But I will know for sure when I get them and I will post pics.
Guys,
Our app chart shows TC-1 for 01-02' ZX with Rack Carbs and TC-4 for 03' and up with rack carbs.
Keep me posted if the TC-1 works on your model 2003 ZX.
Hope this pic helps, The TC-4 is 4" longer from the splitter up and the TC-4 has an inline adjuster for the oil pump.
Thank you,
Wade
RSI
Why can you not make a specially throttle cable for all the ZX chassi with TM-40 rack carbs ????
It has to be longer than the longest Ski-Doo OEM throttle cable for the ZX chassi , part # 512 059 679
The TC-4 is much better suited for the REV chassi
The volume for that application just isn't enough for us to produce.
Sorry
Just looking back in on the ZX section to see wazzup and find the old throttle cable thing still there!
C'mon peeps, I see I wasn't the only one that the PowerMadd ext. worked for w/ no problemo.
First off, you can unbundle your cables, remove a few factory zipties and route them as directly as possible, the 02 oil pump setting was way rich, 03 corrected that.
Bottom line is, if the job adjusting the oil cable is too confusing,
take it to a dealer, they have all the spec's and numbers.
