6to 9000 ' 66gram weights
9000' an above 69 gram
yellow green is the stock primary spring
Ok that helps me out a bunch here Steve thanks
Stock polaris Black/Green spring that I
think is in this clutch is 120/340 ...
The Yellow/Green AC spring according to Aaen is either 122/267 or 134/264, depending on if it's an "arctic Cat" or "Arctic Cat Comet" clutch ... I'm assuming this could be considered an Arctic Cat Comet clutch since it's really similar to Yamaha and Polaris clutches ...?
Either way, I've only got 65g weights in this clutch, and I'm pretty sure with the mods i've done to this motor it's putting out more power than a stock Polaris 900 or AC 900 motor would have been ...
I think what I will do is not screw with my gearing or secondary until I get the primary set up right first, apprently it's way wrong ...
I'll go from here, thanks a bunch guys.
