The PL box will power up with a 9v battery. The power must be applied to the main injector power wire and the main ground wire. The problem you are describing is usually caused by the sled's temp sender showing over heat and will not allow the sled to start. PLT along with others offer hot start swtiches to correct this problem. If you have questions contact me at 801-940-7777
