I put 1-2 gal of 110 oct in with non eth 91 on my silber. At 10-12K it does run a tad rich at 5lbs. But I'd rather run rich for piece of mind
We run 7# all the time @ 9500' and p with 2 gal of 100llc to 4 gal of 91 non eth and it's the way to go on our Silber FWIW.
I ran 7lbs at sea level with 3 gallons of 110 and never had a issue as well.
I had two boondocker inter-cooler kits on pros and installed a silber kit on a new axys in feb. The lag is much more noticeable on the silber and clutching is way to hot. The silber has good power, I picked up different clutching but didn't get to try it. I just ordered a sidekick to install on a customers sled that I ride with, so I will have a good comparison this winter. I ride with several sidekick turbos and they all run good every day. I was tired of the tunnel dump and think silbers kit is more bang for the dollar but really don't like the extra lag.
What Clutching are running? I ride sealevel and we've never ran more than 5# and we are mixing 50:50.
That's got to be a horse @ 7# at sea level!!!!
Sled felt good but always felt better at higher elevation.
I ran exactly what Justin told me to run. I cant remember what that was. It worked perfect.
So you ran the clutching given to you by Justin @ sealevel and ran 7# of boost? What RPM's were you seeing?
thanks every one, got a 2018 bd sidekick on order supper amped hope its as reliable as iv been hearing. has anyone changed any gearing to get more track speed what gages do i need for temp and fuelling is any of that even a worry or just ride it ?
