Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 03-04-2015, 05:24 PM
High Life's Avatar
High Life High Life is offline
Currently: Not set.
High Life has a reputation beyond reputeHigh Life has a reputation beyond reputeHigh Life has a reputation beyond reputeHigh Life has a reputation beyond reputeHigh Life has a reputation beyond reputeHigh Life has a reputation beyond reputeHigh Life has a reputation beyond reputeHigh Life has a reputation beyond reputeHigh Life has a reputation beyond reputeHigh Life has a reputation beyond reputeHigh Life has a reputation beyond repute
Question Help! '13 PC throttle revs, dies
I recently swapped my telescoping steering post for a 4 stroke fixed vertical post set-up and since then have had my sled die about 6 times for no reason. Every time it has done so, I have either been stopped or nearly stopped and had my skis turned full lock to the right. At first the sled would start right back up when I pulled the rope.
Last weekend it quit me 3 times in the parking lot and took a dozen pulls on the rope to start the last time it did it. Once I got it running, I ran it the rest of the day avoiding turning my skis to the right at full lock and it was fine. Even when the sled didn't start, it fired and engine would rev, almost to the point where I would reach for the kill switch before it would die on its own. It acts like there is a safety switch (maybe throttle safety switch in the bars?) kicking in and killing the engine because something is telling it something's wrong. Maybe the throttle cable is out of adjustment or my new steering post set-up is stretching/kinking the cable at full lock to the right?
Anybody else ran into this or heard of this before? Going to look over my throttle cable, but is there somewhere else I should look? Could it be an electrical issue?
__________________
'17 Mountain Cat 162"
Rate this post: Yes | No
  #2
Old 03-04-2015, 06:48 PM
F_ast's Avatar
F_ast F_ast is offline
Currently: Waiting for winter!
F_ast has a reputation beyond reputeF_ast has a reputation beyond reputeF_ast has a reputation beyond reputeF_ast has a reputation beyond reputeF_ast has a reputation beyond reputeF_ast has a reputation beyond reputeF_ast has a reputation beyond reputeF_ast has a reputation beyond reputeF_ast has a reputation beyond reputeF_ast has a reputation beyond reputeF_ast has a reputation beyond repute
Default
You sled it 100% pulling the TSS. Your throttle cable it too tight somewhere. The TSS is a switch that detects cable slack in the throttle block. I would advise against disconnecting your tss at this point as it seems to be telling you something when you turn right.
Either not enough slack in from a riser that it too tall or most likely you need to work on how the cable is routed.
__________________
Horsepower: If it doesn't scare you, you don't have enough.
The Following User Says Thank You to F_ast For This Useful Post:
High Life (03-05-2015)
  #3
Old 03-04-2015, 07:20 PM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Snow angels in dog parks
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Default
When i broke my first steering post on my 09, i routed the cable wrong and turning the bars would pull on the cable causing my sled to rev up enough to engage the clutch, it was like cruise control when u didn't want it. It never caused my sled to die, but that was on an 09, i don't know what has changed on the HO motor.
  #4
Old 03-04-2015, 08:36 PM
bopper bopper is offline
Currently: JST RYD
bopper has a reputation beyond reputebopper has a reputation beyond reputebopper has a reputation beyond reputebopper has a reputation beyond reputebopper has a reputation beyond reputebopper has a reputation beyond reputebopper has a reputation beyond reputebopper has a reputation beyond reputebopper has a reputation beyond reputebopper has a reputation beyond reputebopper has a reputation beyond repute
Default
go inside your throttle block.. you can cut the red or black wire whichever you want and your problems will be gone
  #5
Old 03-05-2015, 10:49 AM
High Life's Avatar
Currently: Not set.
Default
Thanks for the input guys! I only have a 2" riser, so its nothing out of the ordinary. I think I do need to check how the cable is routed though and check my cable slack. Throttle cable doesn't seem tight, but it could be kinked or tight when I turn. I will have to tear things apart to investigate further...
I'm more than a little reluctant to cut any wires. The throttle safety switch appears to be working as it was intended and has already prevented a wreck from my sled shooting across the parking lot and crashing into somebody else's pickup or trailer... Is this throttle safety switch something Cat does since they don't sell their sleds with a tether yet it sort of acts like a tether?
__________________
  #6
Old 03-05-2015, 02:20 PM
M757 M757 is offline
Currently: Not set.
M757 has a reputation beyond reputeM757 has a reputation beyond reputeM757 has a reputation beyond reputeM757 has a reputation beyond reputeM757 has a reputation beyond reputeM757 has a reputation beyond reputeM757 has a reputation beyond reputeM757 has a reputation beyond reputeM757 has a reputation beyond reputeM757 has a reputation beyond reputeM757 has a reputation beyond repute
Default
Does your flipper seem tight against the throttle block? If so you need to adjust your throttle cable down by the throttle bodies to loosen it up. The flipper shouldn't be sucked up tight against the throttle block. Do not cut any wires this is an easy fix you just have to take your hood off and find the throttle cable adjustment.
__________________
05 M SERIES CPC 1000
05 M 757
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — New CAC Video Series “Throttle Decisions” Revs Up Avalanche Safety for Snowmobilers Thread Starter — Avalanche Canada Forum — Avalanche and Survival Replies — 3 Last Post — 12-03-2013 09:20 PM
Thread — 94 AC Cougar Dies with throttle Thread Starter — justjohnthomas Forum — Arctic Cat: Powder Special and older Replies — 3 Last Post — 02-20-2010 11:49 PM
Thread — M8 T Dies when I squeeze throttle Thread Starter — PIKER Forum — Arctic Cat: TURBO Replies — 10 Last Post — 01-21-2010 08:35 PM
Thread — T vector dies when dumping throttle Thread Starter — letsgetrad Forum — Yamaha Replies — 6 Last Post — 02-22-2009 08:09 PM
Thread — Solution to the stiff throttle on REVs Thread Starter — Adrenaline Revolution Forum — Ski-Doo Replies — 0 Last Post — 01-11-2009 12:39 PM
no new posts
