2012 Polaris 800 owners Problems?
06IQRMK
224
27
Anyone out there having problems with their new 2012 800 primary's? I have heard of several instances of people's clutches breaking in half, and jamnuts coming loose... Just wondering if people out there are having the same problems and if so, around how many miles they have/had on them when the problem started???
Thanks!
Murph
Polaris Moderator/ Polaris Ambassador/ Klim Amb.
At this point I kind of wish I was having some sort of problem with my 2012.
Right now it's sitting in the garage with 0 miles on it.
At least if I had a "problem" with it that means I would have been riding it!
Unfortunately, mother nature doesn't have a complaint department!
NDFARMER95
556
108
Mooreton, ND
Im sitting in the same boat with a lot of other people :face-icon-small-fro
owenb2
453
630
93
wyo
400 miles and only one problem, Can't stop smiling!!!! I check clutches and most of the high use/abuse areas every ride, and have never seen anything out of spec.
6 of my buddies bought Pro's this year and only one has had issues, I think it was tps settings.
T G
131
13
18
Nevada
bolt didn't feel bad,screwed puller in an about 1/3 turn with breaker bar pop went primary wow.when i put it on bench my fingers felt funny,took white rag wiped where crank end @end of shaft hum oil.Went to set belt clearence pulled jam nut@spider with 18'' breaker.I'm 63 in fair shape jam nut torque (310 ft-lb) spider(290 ft-lb) what what ya think :face-icon-small-hap if you've pulled one of these apart you know what i'm talking about
