Yamaha annouces BOOST options for 2011 Nytro MTX !!
27,381
Yamaha Exclusive 180 HP Push Turbo / MPI Supercharger for 2011
<hr style="color: rgb(232, 232, 232); background-color: rgb(232, 232, 232);" size="1"> http://www.snowest.com/snowmobile-ne...ay.cfm?ID=2520
Yamaha Announces Major Options for 2011 Nytro MTX
Yamaha-exclusive 180-hp Push Turbo, MPI Supercharger systems
Yamaha announced at a press conference today at Hay Days exclusive power options for 2011 Yamaha Nytro MTX models.
A Push Turbo and MPI Supercharger system will be available through Yamaha dealers later this fall. Both systems will produce 180 horsepower and feature factory presets that eliminate user tuning.
Both the Push Turbo system and MPI Supercharger system are designed for 6,000-ft and higher elevation applications.
Both systems are priced at under $4,000 USD.
Yamaha also announced an optional rear suspension kit for the Nytro MTX that reduces the weight by approx. 25 pounds.
More to come...
UPDATE
Here's the details:
FX Nytro MTX Turbo
By Push Turbo
Distributed exclusively by Yamaha Genuine Parts & Accessories
http://www.pushturbo.com/
MSRP: $3,995
YPAD Part Number: SMA-TURBO-00-00
Fits 2008-2011 FX Nytro MTX Models
Easy installation, only cutting required is a 2-1/4 in hole for charge tube. Turbo comes pre-assembled and mounts above tunnel in place of factory exhaust muffler.
Uses OEM style wiring connectors
180 HP on premium pump gas
8 psi boost (non-adjustable)
1-year warranty (through Push Turbo)
Available exclusively at Yamaha dealerships
For use above 6,000 ft elevation
"The Push Turbo kit is designed only for operation at elevations above 6000 feet. While installation of this kit will not 'void' your snowmobile's warranty, specific failures determined by Yamaha to have resulted from installation of kit components or other modifications may not be covered by the Yamaha limited warranty or extended service coverage." -Official release statement.
FX Nytro MTX Supercharger
by Mountain Performance Inc.
http://www.mountainperformance.com/superchargers.htm
MSRP: $3,995
YPAD Part Number: SMA-SUPER-00-00
Fits 2008-2011 FX Nytro MTX models
Uses OEM Style wiring connectors
Uses stock exhaust
6 psi boost (non adjustable)
Features fuel-only GEMS control module that is non-adjustable
1-year warranty (through MPI)
"The MPI Supercharger kit is designed only for operation at elevations above 6000 feet. While installation of this kit will not 'void' your snowmobile's warranty, specific failures determined by Yamaha to have resulted from installation of kit components or other modifications may not be covered by the Yamaha limited warranty or extended service coverage." -Official release statement.
Photos coming soon...
27,381
Thats a pretty big step forward for Yamaha.
Granted, these are NOT killer stage 3 Turbos or Superchargers, but just that fact that they are offering them is a huge change of course for a very conservative company.
Good changes are taking place at Yamaha that will positively effect our sleds!!
gouldsjett1
New member
47
4
8
boost
What! Nothing for us way down here at sea level? Oh well it is a step forward for yamaha, happy to see them make this move.
27,381
Based on the restricted boost levels (6 or 8psi), I would say they are working to get the mountain riders solidly back to sea level power + a bit more for fun.
R
Dec 3, 2001
2,056
231
CO
Wow, this is mostly a good thing. Reguardless of the fine print. Its a start..a stepping stone.
Hopefully others follow suit.
Granted, you'll now have 25k$ (turbo, suspension, this that and the other) snowmobiles from the factory...just to make a 4 stroke work in the deep n steep... o_O
Edit: For you haters giving negative feedback...I do ride a boosted Nytro (and I quite enjoy it too). I know what it takes to make 4 strokes work at elevation in the DEEP n STEEP. $$,$$$ I'm just not an ignorant Yamaha fanboi (nor Doo for that matter) is all.
motojunkie101
MODERATOR: Premium Member
805
Sandpoint, Idaho
Factory offered low boost for these sleds is a HUGE step in the right direction. The price is still kind of high for what I think a low boost kit should be (IMHO).
This isn't really a surprise though. Yamaha has known for a long time what we want on these sleds, and there have been rumors about them testing boost kits for awhile now.
T
TRUEBLUEMAX
751
280
Hooper, Utah
So it sounds like this is just a kit that you can buy to install yourself is that right? I would assume that this is not a factory option for the sleds. Does it come with any kind of clutch kit also or are you on your own for that?
If that is the case isn't the ulmers kit the same price and it comes with clutching and everything? It is pretty cool for yamaha to be doing this.
fourthmeal
Administrator
Sep 11, 2008
804
1,034
93
Idaho
www.snowest.com
All the details I have (quoted form press release):
Designed for ultimate mountain riding performance
Improved deep snow maneuverability
Improves weight transfer and bump stability
Easy installation using stock shocks and suspension rails
25 pound weight reduction
Fits 2010-2011 FX Nytro MTX models
YPAD part number: SMA-RSUSP-FX-00
MSRP: $929.95
samsquatch47
335
74
St. Paul, AB
This is awesome!
MSRP: $929.95
25 pound weight reduction! Holy crap! Wonder if it's made to hold the front end down better too? Anybody got pics of the kit?
fourthmeal
Administrator
Sep 11, 2008
804
1,034
93
Idaho
www.snowest.com
Rear suspension
samsquatch47
335
74
St. Paul, AB
From the pics it looks like titanium? Chromoly? I am not a skid expert, so to you experts does this look like a coupled skid or noncoupled? The factory 2010 skid is uncoupled right? This is why it wheelies under boost so bad?
Thanks
backcountryislife
7,413
Dumont/Breckenridge, CO
This is pretty great news, both for Yammi & the industry as a whole far as I'm concerned! It'd be pretty cool to be able to go buy a factory turbo for the other brands, I hope this move pushes that closer to reality.
TBird
673
149
North of Sweden
It looks like an completely uncoupled skid.
And from the text "Improves weight transfer" = more wheelies!
