M
first let me state this...there are a lot of haters out there regarding kelsey. maybe some of them are justified maybe not. there are always two sides to every story. here is mine. for whatever reason kelsey contacted me and asked if i wanted to see what my sled could really run like. obviously i said yes but that i was tapped out monetarily speaking. well long story made short... kelsey's kit shows up at my door FREE OF CHARGE. i dont care who you are thats pretty cool.
well i ran the kit yesterday in 18-36" of FRESH powder. worked great. the shifting characteristics were fantastic. what i noticed right away was how it upshifted quicker thus snapping the sled up on top of the snow quicker. back shift was better than my other setup but not as noticeable. my other setup actually backshifted quite well. the other thing i noticed was topend(when climbing) pulled better. i didnt stop and check clutch temps... too busy having fun.pulled rpm(and stayed there) no matter if i was in deep snow or on loose snow, hardpack etc. NO INCONSISTENCIES! i know the kit is getting the power to the track now. reason being i saw the highest egt's to date. kinda scared me. the motor is being loaded more or properly now. i will be keeping this setup on my sled for the duration. very pleased. it PERFORMED as ADVERTISED.
now to be fair my other setup was quite good. just not as good as the RKT kit. for those who dont have the money my old setup(mtn extremes clutching)is a way good second option. especially considering what the clutching is like from the factory.
i know what some of you guys are thinking.... kelsey gave me the kit therefore i am obligated to give a positive review. not so! i admit i was stressed prior to testing but if it had not performed i would have told kelsey and then the SW peeps. it is what it is... kelsey's products flat out work! i am by no means a mechanical genius but the kit was extremely easy to install. very well built and great machine work.
here is my old setup followed by the RKT kit:
cutler adj. 65gram base weights with the 5/8" screw at the heel
AC gold pri. spring
dalton 45/38-36* helix
m8 org. sec. spring with the adj. at the cover. (this setup is for sale)
046 belt
d&d shift assist
cutler adj. 65gram base weights with the 1/2" screw at the heel
AC gold pri. spring
rkt 34* helix
snopro green torsional sec. spring in the middle hole
046 belt
now this is early testing so i am going to change a few things. i am going to try the stock 68gram arms and the AC org/white in the primary. this is kelsey's recommendation. i wanted to run the gold spring and cutler weights to get a baseline and compare that against the stock arms and org/white. i will report back with the results.
AC gold pri. spring
046 belt
d&d shift assist
AC gold pri. spring
rkt 34* helix
046 belt
