I read all about the recommended replacement bolt,but looking for advice on removing broken bolt. It broke off about 1/16 inside the shaft. Heat for lock tight loosening, then the best easy out? Square fluted, tap in then turn out or normal ez out? Done by leaving shaft in place? Angle drill shoul be able to access it.
Thanks
Thanks
