H
2012 Pro with 3000 miles. Engine rebuilt couple years ago and sits at 120psi per cylinder cold.
For some reason takes 5-6 pulls to start cold, fine when it's warm. Won't go into reverse, idles around 1450-1550 RPM and no matter what I do it won't go into reverse. Yet sometimes it does, very rarely.
Today I re adjusted my TPS, figuring it was out of spec. I removed the cable (brand new) from the throttle, backed the set screw off on the throttle bodies, and set the base TPS setting to .700 +/- .01 V .. Then I turned the set screw in until I got .940 +/- .01V and set. Then I reconnected the throttle cable and adjusted the free play from there.
I'm kinda lost, everything else works perfect. Any ideas would be great thanks!! Wanna get out and break in the wife's sled but need mine running good too!
