Anybody try different driven clutch springs in the m8000? I can't find much info on springs or even helix options.
Geared 20/49 with stock drivers and 2.6 162 track. There must be something up with the secondary on these sleds. It works alright it just doesn't load the motor and pull. same motor same clutching in primary on the 2010 and it will pull all the way to full shift. Sometimes you can clutch and get perfect r's but the sled just doesn't put it to the ground. My old D&D 860 was that way and I kept adding weight in the primary. The r's stayed the same but it just kept pulling harder and harder.:face-icon-small-conAre you running the stock helix?
What is your gearing?
What size drivers?
What size track?
you guys should clarify if you are asking about a 16 M8000 with TEAM sec or previous years with Cat sec, I may have missed something but it appears we have guys talking about both
