Was riding cooke this weekend and my sled would only pull about 7600 rpm. Looking for ideas on what could be wrong.
Background:
2016 Axys 800 155
1000 miles
Ran first two years stock
This was first ride with bmp pipe and bullydog
Sled has had some electrical issues in the past that caused some issues like this, but a bit different. (New wiring harness and stator warrantied end of last season).
Also has had issues with primary moveable sheave bushings swelling.
Stock i would have ran 62 or 60 gram weights. I started the weekend off with 66's for the bullydog setup (supposed to run about 4 grams more weight). Also using a borrowed clutch that is all but new since mine is at the shop getting a bushing put in. We got up to elevation and started riding, i noticed i couldn't pull over 7600 rpm. My buddy had a set of 60 gram weights that we threw in to see if we could pick up some r's (yes 6 grams lighter). After putting those in i could pull 7900-8100, but my bottom end was noticeably weaker. Other than that the sled ran SUPER clean with the bulldog bikeman tune. That makes me think the bmp setup is not the issue, but who knows. Has anyone else had similar issues and if so, what caused it?
Background:
2016 Axys 800 155
1000 miles
