Note: this_feature_currently_may_not_be_available_in_some_browsers
Ignition Coil Primary (External) Secondary
0.26-0.35 ohm 6800-10,200 ohms
orange high tension wire
black high tension wire Charge Coil (1) 12-18 ohms black/red green/red Charge Coil (2) 12-18 ohms brown/white green/red Ignition Timing Sensor 148-222 ohms green/white brown Lighting Coil 0.12-0.18 ohm yellow yellow Spark-Plug Cap 4000-6000 ohms cap end cap end
This is on a 500 mc with out APV,
http://countrycat.com/ccstore/kbase/snow/2005/Section5.pdf
Many times the stator will check out within the limits but it is your issue, with the age I would lean towards the stator.
