Carbs: 40 pilots, p8 needle jets(nozzles), Q0 below 2000 feet,3.0 cut away on slides (I ground 2.5 to match 3.0),6DH8 needles, clip in the center, 340 mains. clutching: Drive clutch 57 gram weights, square almond spring ( make sure its not in backwords or just use a spring thats about a 150 340 rate) Driven clutch team clutch red black spring,straight 36 helix button clutch silver blue spring (set in 2 hole) straight 34 helix Gear to 2.15 ratio. 3.0 pitch track 162" 2.25 power claw is sweet (used to run 2.52 pitch 2" chalenger 9 tooth extravert drivers) Retard rmk timing a little, leave sks timing alone. I ride mostly the mountains of priest lake idaho, 2500' to 6500'. nearly 15,000 miles on this set up with 2 rebuilds. Runs very well. Slp heads
