Just so happens I wound up with my old 14.
The 18 is a great sled and I am not trying to take away from what it is. I am however telling anyone wanting more how to get it.
The only place the 14 outperformed was when you really load the track in a climb or hard technical turns where you can plant the track and wheelie to maneuver.
Otherwise the 18 is pretty much what I've been shooting for since '12. Although now the boards need improved and raised, add steering, grippers, clutching and gears. I guess there is a lot to do.
Anyway, the new clutching works pretty good but not as good as the old if fixed.
The 18 primary is good.
The secondary works but doesn't work, the gearing is wrong.
The 14 has a ds can, 911 clutch cover,
stock weights (I ruined the Mds before I sold it because the clutch failed) the Mds actually pulled harder.
The 14 secondary machined by Tom @Mountain valley motor sports in Cody, wy (this is key)
Tki belt Drive with 2.42 gears, 8 tooth drivers with 3" pc.
Burandt boards and steering mod, otherwise stock.
No HP mods. In reality only about 20lb weight loss but i was packing 8-10lbs on the sled that the 18 wasn't.
CO2 and i compared his 16 to the 14 and without gear I'm 55lbs heavier. The 14 pulled on his 16. We switched and I couldn't even pull the hill on his 16 and he flat walked away. It was baffling.
The 18 was better but was also a 162, but it just didn't have the pull. Great all around but the 14 felt like a diesel compared to the others.
On the flat the 18 would walk .5-1.5 lengths right off, I had to lean forward and ease into it to stay within .5.
Then it pulled in the mid a length then ran even.
The pull in the mid wad the only thing that really impressed, but I outweighed the rider on the 18 by 60lbs.
18 is impressive but why is the 14 pulling away when loaded.
I believe it is mainly the diameter of the secondary inner circle.
As much as I would hate to do it, I would go back to the 14 Jack shaft and secondary with machine work and gear up. I just can't leave that much on the table.
Everything I've tried in 16 and 17 never felt right and I knew there was more, now it's proven.
But the 18 is still an animal but I don't like the 162. 153 is a better combo.
As for you turbo guys, it really needs the other clutching to use that boosted torque.
Btw, the 14 is for sale $5500 obo 1180 miles. Needs to go. I'll sell it for 4500 without mods. ($4400 worth of mods)
Or I'll trade someone the mods for stock parts and 2000 (tki, machined secondary, 911 cover, d's can, 3" track)
Also have a mountain fit hood to deal with.
