A
I experience a low end bog on my 2010 m8 162, I have checked clutching, power valves, can, intake, etc etc... I will check the oil pump, and if that is not the problem I will most likely take in the ecu for a new fuel map. Has anyone else done this? I know arctic cat has a recall for these sleds, as I know that the 2011's do a lot better on the lower end.
Let me know if you have had success (or failure) with this, so many posts ive seen about these sleds seem unsolved. My sled runs awesome when it clears out, I just need to work the throttle right. The dream of course is to have power from idle to 8000 rpms.
thanks in advance
thanks in advance
