Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 01-23-2011, 01:36 PM
Wire4Money Wire4Money is offline
Currently: Not set.
Basic Member
Wire4Money has a reputation beyond reputeWire4Money has a reputation beyond reputeWire4Money has a reputation beyond reputeWire4Money has a reputation beyond reputeWire4Money has a reputation beyond reputeWire4Money has a reputation beyond reputeWire4Money has a reputation beyond reputeWire4Money has a reputation beyond reputeWire4Money has a reputation beyond reputeWire4Money has a reputation beyond reputeWire4Money has a reputation beyond repute
Default Belt squeal
My friend has an m8, put the carlisle xs belt on, it squeals on idle. I blew a belt on my M7, and put an xs on it, and it squeals on idle. Is this a trait of this belt? It is rather embaressing.
Rate this post: Yes | No
  #2
Old 01-23-2011, 01:43 PM
XFIRE800's Avatar
XFIRE800 XFIRE800 is offline
Currently: Not set.
XFIRE800 has a reputation beyond reputeXFIRE800 has a reputation beyond reputeXFIRE800 has a reputation beyond reputeXFIRE800 has a reputation beyond reputeXFIRE800 has a reputation beyond reputeXFIRE800 has a reputation beyond reputeXFIRE800 has a reputation beyond reputeXFIRE800 has a reputation beyond reputeXFIRE800 has a reputation beyond reputeXFIRE800 has a reputation beyond reputeXFIRE800 has a reputation beyond repute
Default
add or remove shims to adjust deflection
  #3
Old 01-23-2011, 01:45 PM
AaronBND's Avatar
AaronBND AaronBND is offline
Currently: is figuring shit out!
AaronBND has disabled reputation
Default
It kills me that so many guys don't know the very simplest maintenance things.......
The Following 2 Users Say Thank You to AaronBND For This Useful Post:
Dam Dave (01-23-2011), FreeAgent (01-27-2011)
  #4
Old 01-23-2011, 01:56 PM
Rixster's Avatar
Rixster Rixster is offline
Currently: I love you El Nino
Rixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond repute
Garage
Default
Just take a shim out of the secondary.
__________________
Custom built sled decks contact me for details
A.K.A."Seth"
06 M7 CPC Dragoncat 1000 162
F350 crewcab
Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, body thoroughly used up, totally worn out and Screaming "WOO" What a ride!
KCCO
  #5
Old 01-23-2011, 02:33 PM
Currently: Not set.
Basic Member
Default
Quote:
Belt deflection is not covered in the owner's manual (which has more maint info than any I've seen.) I have changed a few belts on past sleds (this is my first Arctic Cat) and have never had to adjust anything.
  #6
Old 01-23-2011, 03:36 PM
Rixster's Avatar
Garage
Default
Quote:
I have to adjust mine every 3-4 rides, or as the belt wears.
__________________
A.K.A."Seth"
F350 crewcab
KCCO
  #7
Old 01-23-2011, 04:24 PM
CATSLEDMAN1 CATSLEDMAN1 is offline
Currently: one ski and a KTM
CATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond repute
Default
So, wire4 money we need to know what sled and clutch system to have to help you. Squealing belts at ide means the inside of the belt is rubbing on the center of your drive clutch so hard its starting getting sticky and starts squaling sound.
So you need to loosen your belt, done by making the distance bewteen your secondary sheaves wider apart. So add a shim on the old cats, adjust on the DD, and on real old cats buy a longer belt.
  #8
Old 01-23-2011, 04:34 PM
miko miko is offline
Currently: Not set.
miko has a reputation beyond reputemiko has a reputation beyond reputemiko has a reputation beyond reputemiko has a reputation beyond reputemiko has a reputation beyond reputemiko has a reputation beyond reputemiko has a reputation beyond reputemiko has a reputation beyond reputemiko has a reputation beyond reputemiko has a reputation beyond reputemiko has a reputation beyond repute
Default
I've found the carlisle xs belt sits higher on the secondary making it sit in the primary deeper and creating the squeal. Just like the others said add a shim to the secondary, get an arctic cat belt or get used to the squeal.
  #9
Old 01-24-2011, 12:17 AM
aktreekiller aktreekiller is offline
Currently: summer go away
aktreekiller has a reputation beyond reputeaktreekiller has a reputation beyond reputeaktreekiller has a reputation beyond reputeaktreekiller has a reputation beyond reputeaktreekiller has a reputation beyond reputeaktreekiller has a reputation beyond reputeaktreekiller has a reputation beyond reputeaktreekiller has a reputation beyond reputeaktreekiller has a reputation beyond reputeaktreekiller has a reputation beyond reputeaktreekiller has a reputation beyond repute
Garage
Default hey
I adjust my deflection so that the track slightly turns on a track stand, have run like that for 1500 miles. 1200 miles on first belt and decided to change it out. It sqeals at idle sometimes after a couple wide open pulls, but I'v always ignored it.
  #10
Old 01-24-2011, 04:59 PM
POODRAGON POODRAGON is offline
Currently: Not set.
POODRAGON has a reputation beyond reputePOODRAGON has a reputation beyond reputePOODRAGON has a reputation beyond reputePOODRAGON has a reputation beyond reputePOODRAGON has a reputation beyond reputePOODRAGON has a reputation beyond reputePOODRAGON has a reputation beyond reputePOODRAGON has a reputation beyond reputePOODRAGON has a reputation beyond reputePOODRAGON has a reputation beyond reputePOODRAGON has a reputation beyond repute
The Following User Says Thank You to POODRAGON For This Useful Post:
j hoalst (01-24-2011)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Apex belt squeal Thread Starter — b_sandgren Forum — Yamaha: 4-Stroke Replies — 9 Last Post — 11-29-2010 01:38 PM
Thread — Squeal from reverse Thread Starter — paramuir Forum — Polaris: 900 Replies — 11 Last Post — 02-18-2010 01:56 AM
Thread — traditional yammi belt squeal Thread Starter — Ringer Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 21 Last Post — 01-05-2010 01:14 PM
Thread — Belt or clutch Squeal ?? Thread Starter — ronmexico78 Forum — Polaris Replies — 5 Last Post — 02-22-2009 10:04 AM
Thread — Belt squeal? whats up? Thread Starter — ZL50068 Forum — Mountain/Deep Powder Replies — 15 Last Post — 12-06-2007 03:03 PM
no new posts
