clutch engaging too low?
Sep 20, 2011
51
Central Minnesota
i have a 97 polaris super sport 488 and it seems that the clutch engages at way too low rpms, it usually engages around 3600 rpms, i would like to have it engage around 400 or 4200, it there anyway to change this without buying anything? or do i have to buy a new spring? thanks!
also if i do have to buy a new spring where can i get one? :plane:
V
volcano buster
1,614
Stayton Oregon
Sounds like a spring is in order. Is the top end still good, over-rev, or still good power?
Your dealer should be able to set you up with the correct spring. It is likely sacked out from years of tension being trapped in the clutch so a new one is going to make difference.
