SLP Pipe Issue
zachman33
179
33
Washington
So I installed my SLP pipe setup and as I assumed it rubs and melts a little on two spots of my hood. Can someone direct me to a hood lift kit of some sort to move my hood up a couple of inches? Also does anyone have some pics of the install? Thanks!
A
arctic2009
1,864
670
Minnesota
Im thinking the bolts on the cylinders only allow the y pipe to go on one way. at least thats how it was on my 09.
summ8rmk
Most handsome
12,368
6,039
yakima, wa.
I put 3 layers of heat tape and the pipe heated up the intake and re molded it for me lol. It worked out rather well. :face-icon-small-con
zachman33
179
33
Washington
You are right Arctic cat 2009 it can only goes one way. I did follow every step on the SLP directions. My buddy's HCR melts and rubs a little bit in the same spots mine does. What tabs are you talking about?
A
arctic2009
1,864
670
Minnesota
The tabs underneath the hood near the upper vents in the hood. They are for the clips that hold the hood screens in.
D
Feb 14, 2008
3
58
Anchorage Alaska
On my 09' it was rubbing the screen tabs and just to the left pto side on the air box. I just took a hand grinder to the rubber mount that the pipe sits on, didn't take much to get it to clear....
D
Oct 20, 2008
90
8
8
Two things I did when I installed the SLP pipe on a 2009 M8 was 1: Heat gun to the air box and push in just enough to allow for the clearance, but this was done after 2: The rubber snubber the pipe sits on, just over the secondary clutch, I cut this down a little, not much, but a little, and then heat gun to the airbox. Heat tape areas that get the most heat, and never had a problem.
zachman33
179
33
Washington
Ok perfect, sounds good. Thank you for your help, I will try that!
G
glaciermonkey
158
12
18
skidro willey, wa
Yep,
I put the SLP kit on two 09 sleds one fit great the other had some clearance problems. I took a heat gun to the air box and remolded it to provide the clearance I wanted.
this is what i did, worked great. if you do this remove the air plenum from the sled first.
also, i put a 3/16 stainless nut and bolt through the holes that the windshield tabs go through. this holds the plenum tight to the hood
