T
throttlecable
372
334
Fruita, CO
You should have plenty of power for a 159", but I would gear down 1 -2 teeth for best results. Also make sure the pitch is compatible with your drivers, or get aftermarket extro's that match the track pitch.
M
108
It will have the power. Gearing down will help alot.
I have a 20 tooth top gear that I had on my Mountain Max when I went from a 141 to a 151. If you are interested in buying it PM me
If you do the anti ratchet drivers (highly recomend) I have a diagram with measurements that show correct placement for the driver on the shaft.
B
Dec 21, 2007
577
132
Kalispell, MT
159=excellent choice
i run a stockish 700 viper with a 159" challenger lite. gearing is 18/42 with clutching and it works very well. the key to the setup is the 42/43 bottom gear and run whichever top gear works for your application. the 159 makes a huge difference in flotation and deep snow ability. you will not be disapointed.
