Is the t-bap sensor still plugged in? I also have never heard of one failing.
how many times does your light flash befor it pauses for a second?i have a 08 d7 with bd turbo and am having problems too. my light flashes just as it comes under boost then stops after 7800 wot. but mine has no bottom end it is driving me crazy. what are your tuning #s if u dont mind. im running 7lbs of boost with 91 pump gas.
checked the exhaust valves and cleaned them. spring and belows are fine. what rpm do they open and how do they work with that selonoid?just a stab in the dark here but could it be the exhausts valves? sounds similar to the symptoms
Attitude boxes are the way to go they are ten times easier to tune with!
