When it comes to what your gauge is reading that is... :face-icon-small-hap
This thread is intended to be a DISCUSSION... The opinions presented here are just that OPINIONS... Especially mine :face-icon-small-coo
This conversation was started in another thread and was off topic (my bad)... so I thought I'd "bust it out" and bring it here for discussion.
In this day and age of new turbo systems... More Pull-N-Go than we have ever been... this may help some to understand what is going on in terms of Boost pressure and what you see on a gauge and what is happening.
Some Acronyms:
IMO = In My Opinion
PSIG = Pounds Per Square Inch GAUGE
PSIA = Pounds Per Square Inch ABSOLUTE
EBC or EABC =
Electronic Boost Controller
or Electronic Altitude Boost Controller
MAP = Manifold Absolute Pressure
From This page: Click
That is incorrect. The amount of oxygen molecules per square foot (or whichever area measurement you prefer) is going to be less at higher elevation. This is easily overcome by increasing the boost level as you climb in elevation. The MAP (manifold absolute pressure) sensor incorporated into the system will read the air pressure, which not only changes with altitude change but with temperature and weather changes as well, to the electronic boost control. The EBC will keep the pressure at the manifold the same by increasing or decreasing the boost accordingly. This is why it only takes @3 lbs of boost at sea level to make 200 hp but 6+ lbs of boost at 9000 feet to make the same 200 hp.
A boost gauge does exactly what Hobbes is saying.... reading PSIG
I'll refer here to "EBC" as an electronic boost controller that will adjust, automatically, for changes in altitude (barometric presure) as well temperature.
The "EBC" systems work off of ABSOLUTE pressure sensors to read manifold pressure.
So, your Gauge will read higher boost at higher altitudes when the "EBC" is functioning as intended as compared with the same EBC functioning as intended at lower altitudes....
While is is true that your "boost gauge" is reading "higher boost pressures" at higher elevation... the "EBC"/Turbo is NOT making more boost at altitude... although the turbine/compressor ARE spinning faster.... actually the MAP remains constant (or at least that is the target that we are shooting for)
AND...
The pressure on the charge side of the system (charge-tube/airbox/throttle bodies/BOV) , ABSOLUTE PRESSURE, which the MAP sensor is reading... That pressure will remain constant at WOT... and thus the oxygen content in that air-charge will also remain constant (or increase if target boost is dialed-up)... for our intents and purposes here.
Now... some well equipped people will have a gauge that reads PSIA.... like an AEM X gauge with MAP-sensor... or other PSIA gauge.
I wonder why 2-stroke turbo mfgs have visual-gauges that read PSIG... when the "EBC" system reads PSIA.
I'd rather know what the manifold is reading, rather than the gauge-pressure which is compensated with ambient atmospheric pressure.
Although most don't need a system... And I would argue that it can take away from that pull-n-go motif... It would be nice to have a MAP-gauge avail as an option.
It is true that there is the same PERCENTAGE of oxygen in a given volume of 'air' at altitude.
Example... blow up a balloon... which is a 'container' that can expand...at sea level, that balloon will be smaller in size than it will be at 10000 feet (as long as it doesn't burst)... That balloon contains the same air at both altitudes...only the density changes (units per given volume).
Since a turbo must spin more to collect less dense air at high altitudes.... the efficiency drops at higher altitudes.
Analogy.... How many 5 gallon buckets of blower powder would you need to collect 10 gallons of water once melted... how many buckets of spring snow would you need to collect that same 10gallons of water.
A given PG turbo sled with a funtioning "EBC", running MAP at 20.7psi (1.4 bar) , will have a different throttle response at sea level than at higher elevations with the same 20.7psi MAP.
So long as the kit mfg did their homework in selecting the correct compressor/turbine/housing... and the sled is working inside of those parameters that the mfg used to select the turbo... all is good.
That being said, there can be improvements made in HOW well a turbo kit works by narrowing down the 'window' of altitudes that it is designed to Optimally perform in. Even with an "EBC" some compromises are made if the turbo is selected to have optima response and power at, for example, sea level compared to, say, 9,000 ft.
In a well designed sled turbo kit, I would expect a slightly different turbo configuration for customers who run mostly at lower elevations than at higher elevations...so that the sled has optimal running characteristics (throttle response, minimal lag, lower charge temps, outlet backpressure...etc... etc) for that target range of elevations most ridden in...and any 'compromises' are made only when you are operating outside of you preferred range.
Either way, you are NOT MAKING THE SAME HORSEPOWER AT 9000 FT THAT YOU ARE AT 1500 FT unless you are adjusting your boost pressure.
Hobbes.... You are talking about "Gauge Pressure".... not MAP, Correct?
An "EBC" works to maintain near consistent MAP at different elevations....so long as the turbo is capable of handling those variations.
IMO... From a consumer aspect... it would be great, from an intuitive level, to talk about boost as MAP...Rather than Gauge boost readings that are "compensated".
Most people that own turbo sleds don't know, nor should they need to know, how the system works... unless they are really are 'tuners'.... 90% of the people, IMO, that buy a turbo kit for their sled really just want a "pull and go" system. Having a gauge that reads 10 lbs of boost when they are riding and they purchased a "6 lb PG" system just makes them nervous.
Correct me if I'm wrong... a sled will have the same power at all elevations if the MAP is consistent at those different elevations. You are not actually making "more psi"... you are keeping the MAP at a consistent psi number.
Example... if you were to hook your typical boost gauge to a sealed bottle... and pump that bottle, at sea level, to say 10 psi reading at the gauge.... and you took that sealed bottle with your boost gauge to 9,000 feet (using Max's 10.5 psi ambient number).. Your gauge would now read 14.2 psi, at 9,000 feet... without changing a thing in the bottle.
Of course the turbine section is affected as well from the changing differential of exhaust pressure and ambient baro... which changes how the turbo works as well. A properly selected turbo and functioning "EBC" will help to mostly negate this effect.
