Speedwerx Limited Edition Turn-Key Sled Packages
As many of you may already know, here at Speedwerx, Inc. we strive to bring our customers, clients, dealers and friends the best possible products, service and support in the industry. In an effort to continue raising the bar, we have begun to offer completely custom turn-key limited edition sleds.
2017 M 8000 Mountain Cat 153” with Stage 2 Exterminator Kit - 15-20 lbs. weight loss depending on muffler choice
$16,999.00
Includes:
Speedwerx Fat Daddy Single Pipe & Y-Pipe
Speedwerx Lightweight Muffler
Speedwerx Hypershift Clutch Kit
Boyesen Rad Valves
Speedwerx High Flow Intake
Dynojet Power Commander V Fuel Controller
Speedwerx Limited Edition Sled Wrap
Built & Tested by Speedwerx
2017 M 8000 Mountain Cat 153” 225 HP with Speedwerx Supercharger Kit
$22,999.00
Includes:
Speedwerx Pump Gas Supercharger Kit
Mountain Fit Lightweight Hood
Dynojet POD-300 Display & Mount Kit
Dynojet AT-200 Air Fuel Meter
2017 ZR 8000 Sno Pro 137” with Stage 2 Exterminator Kit - 15-20 lbs. weight loss depending on muffler choice
$16,999.00
Includes:
Boyesen Rad Valves
Speedwerx Timing Key
Arctic Cat Tunnel Protectors
Woody’s Studs & Colored Backers
Woody’s Carbides/Runners
Test Results using V-Box GPS Data Recorder:
--2016 ZR 8000 137" Stock 1.25" lug track with Woody's studs 3 per bar with every other on the outside band
660' 88.05 mph - 1/4 Mile 96.07 mph - peak 101.32 mph @ 8100 Max RPM
--Same machine with Speedwerx Stage 2 Exterminator Kit
660' 93.02 mph - 1/4 Mile 102.66 mph - peak 106.39 mph @ 8350 Max RPM
https://www.youtube.com/watch?v=MMX7J0U6k1A
2017 Arctic Cat Thundercat - Horsepower Gain & Weight Savings - TBD
$19,999.00
Includes:
Speedwerx ECU Mapping
Speedwerx Full Stainless Steel Exhaust
Speedwerx Aluminum Charge Tubes
Woody’s Studs with Colored Backers
Only 5 of these machines will be built by Speedwerx (Offer ends April 15th.)
$1000.00 deposit required by April 15th.
$9000.00 due June 15th.
Balance due upon completion.
3% credit card fees apply.
If you are interested in obtaining one of these sleds or upgrading your current sled to this package, please give us a call at 651-982-6020. These sled packages are available to anyone and everyone including our dealers and distributors.
